How do you check the amount of wifi used monthly through the modem? I don’t want to check through the my provider. Also, is it possible to disconnect or pause devices on WiFi through the app or is an update coming for that?
You posted in the cable modem side.
What device do you actual have? A modem alone won’t have that info.
Model g36
