SERVICE PROVIDER = COX, 2GB SUPER FAST SERVICE
CABLE MODEM = ARRIS S33, connecting to the router using the 2.5 Gbps port
ROUTER = NIGHTHAWK XR700
In order to get the use out of 2.5Gbps service from COX, I have to use the 10 Gbps SPF+ port on my router, else I will still be bottlenecked by the 1Gbps port. I purchased an SPF + transceiver (2 different ones) that both say they are compatible with my Nighthawk/Netgear.
When I try to connect this together, I keep getting an error indicating that I cannot get connected to my ISP aka Cox. Put the cable back into the 1Gbps port on the Nighthawk and all is well.
So I have a few hypothesis:
- Arris S33 will not work with an SPF+ transceiver
- Cox will not work with an SPF+ transceiver
- Both transceivers are defective though I do get clear link light activity from both the Arris and the Nighthawk using the CAT 6A cable (I have also tried different cables)
- I have misconfigured my router somehow (although I do have it set to read the SPF+ 10Gbps port vs. the 1Gbps and have tried it with both DAC turned on and off)
It feels to me like this is really more of an issue with 1 or 2. Does anyone have their Arris S33 working with Cox AND using a router with an SPF module in it?
