I am constantly losing connection to the internet and see the following errors in the modem logs
CMSTATUS:DS_Diplexer_Mode_Change_Ignored
CMSTATUS:US_Diplexer_Mode_Change
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=6c:13:d5:75:6f:21;CM-QOS=1.1;CM-VER=3.1;
Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=6c:13:d5:75:6f:21;CM-QOS=1.1;CM-VER=3.1;
So far Cox has replaced the line from the pole to the modem, talked to multiple cox agents who have reset the modem and the issues are still happening.
I have also done a reset via the reset button on the bottom of the modem restoring factory defaults. over this past weekend I have sections of modem logs missing, it there a limit of how much it will keep? I have noticed this behavior over the past couple of weeks.
