Is the S33 a modem/router combo or just modem? I’m not talking about WiFi, I just need to be able to physically connect multiple devices to the LAN interface using a switch and want to make sure it hands out DHCP IP addresses. From what I’ve found the default IP is 192.168.100.1 so it does do some routing but want to make sure I can connect multiple devices on the inside.
