I am linked with my eero pro 6e router through the 2.5g port but there are no link lights. I also noticed when I boot the modem there are no lights on the 2.5g port but the 1g port has lights. Any thoughts?
2.5g lights not working on S33
I understand that the 2.5G port is working, but there is no light. This is normal behavior as long as the port is functioning properly.
You can try power cycling the modem, and if the issue persists and it concerns you, a factory reset may be worth considering.
Since the port is operating correctly, there are no issues with the modem itself. However, if you have any concerns, you can visit www.arris.com/consumersupport for further assistance.
