Arris Modem getting hot and slow speed S33
  • September 5, 2023
  • 798 views
Hi! I use eero pro 6e and I’m not getting the over 1 GB for wired in a 2.5 gb port. Anyway can get a replacement? This unit feels hot as well.
no longer need this question.
Best answer by LoveMyLab
Can we get more details? How are you testing? It sounds like you are expecting to get greater than 1 Gbps on a device downstream via the eero pro router. Step 1 is to plug a PC into the Modem via ethernet, reboot the device, and then check the speed from your ISP to the Arris. It may be you are only getting 960 Mbps, depending on the ISP and the configuration. Additionally, you’ll have to know what kind of Network Interface Card (NIC) is on the PC. It may not support anything over 1 Gbps. These steps will help determine whether there is a real problem or not.
LoveMyLab
Guardians of the Gateways
Forum|alt.badge.img+19
  • Guardians of the Gateways
  • September 6, 2023
