Arris S33 Port Grounding
Does the Arris S33 Cable modem have a RJ45 Port grounding? I see the metal on the outer edges of the RJ45 port but I just want to make sure?
The reason why I ask this question is because of this picture I am acting to this thread. I have cat8 S/FTP Cables and I am worried about the ( ANTENNA EFFECT).
Basically the one question I have is if there is metal on the edges of the RJ45 Port does that indicate Port grounding?
Thank you in advance for your help & time!
have a wonderful day!
Hi Hypnotized,
 Port Grounding will not be happening on the S33 modem .
Hi Hypnotized,
  • July 24, 2023
Thank you for the reply. So quick question, When a device has the three prong outlet that plugs in the wall instead of the two Prong outlet Would that indicate that the device is grounded? So if the device had a three prong outlet that plugged in the metal casing around the r j forty five ports without me in the ports for grounded?
