Arris S33 V2 intermittent internet connection
Hello community members ,
I recently purchased a refurbished Arris S33 v2 for my 1g connection from Optimum.
And I am getting random internet cuts for like 1 minutes and comes online again on its own.
I have a Mikrotik router behind S33 modem.
when modem goes offline I can clearly see the public ip on wan interface gone and replaced with 192.168.100.10. I don't have to reboot or do nothing it comes online on its own.
and below is my log
No Ranging Response received - T3 time-out;CM-MAC=edit:personal information;CMTS-MAC=edit:personal information;CM-QOS=1.1;CM-VER=3.1;
31/12/1969
18:50:46
3 DHCP failed - RS sent, no RA received;CM-MAC=edit:personal information;CMTS-MAC=edit:personal information;CM-QOS=1.1;CM-VER=3.1;
12/5/2024
13:24:59
3 Successful LAN WebGUI login from 47.219.233.94 on 24/05/12 at 1:34 PM.
31/12/1969
18:50:16
3 CMSTATUS:US_Diplexer_Mode_Change:Init, 5-42MHz.
31/12/1969
18:50:19
3 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=edit:personal information;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
31/12/1969
18:50:20
3 CMSTATUS:US_Diplexer_Mode_Change:TLV-9, 5-42MHz.
31/12/1969
18:50:27
3 No Ranging Response received - T3 time-out;CM-MAC=edit:personal information;CMTS-MAC=edit:personal information;CM-QOS=1.1;CM-VER=3.1;
31/12/1969
18:50:46
31/12/1969
18:50:16
31/12/1969
18:50:20
31/12/1969
18:50:22
31/12/1969
18:50:26
3 No Ranging Response received - T3 time-out;CM-MAC=edit:personal information;CMTS-MAC=edit:personal information.1;CM-VER=3.1;
31/12/1969
18:50:51
3 DHCP failed - RS sent, no RA received;CM-MAC=edit:personal information;CMTS-MAC=edit:personal informationCM-QOS=1.1;CM-VER=3.1;
31/12/1969
18:50:15
31/12/1969
18:50:19
31/12/1969
18:50:21
31/12/1969
18:50:25
3 No Ranging Response received - T3 time-out;CM-MAC=edit:personal information;CMTS-MAC=edit:personal information;CM-VER=3.1;
31/12/1969
18:50:32
6 Honoring MDD; IP provisioning mode = APM
31/12/1969
18:50:48
31/12/1969
18:50:50
5 DHCP WARNING - Non-critical field invalid in response ;CM-MAC=edit:personal information:CMTS-MAC=edit:personal information;CM-QOS=1.1;CM-VER=3.1;
12/5/2024
17:45:24
4 Primary address failed, secondary active;CM-MAC=edit:personal information;CMTS-MAC=edit:personal information;CM-QOS=1.1;CM-VER=3.1;
12/5/2024
17:45:25
6 TLV-11 - unrecognized OID;CM-MAC=1c:93:7c:a5:2c:a1;CMTS-MAC=edit:personal information;CM-QOS=1.1;CM-VER=3.1;
12/5/2024
17:45:30
6 DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=1c:93:7c:a5:2c:a1;CMTS-MAC=edit:personal information;CM-QOS=1.1;CM-VER=3.1;
12/5/2024
18:41:31
3 Successful LAN WebGUI login from 47.219.233.94 on 24/05/12 at 6:51 PM
As we checked the cable signals, under downstream channels all the signals are in range. But for the upstream channels, power levels should be greater than 45dbmv.
I suggest to contact internet service provider to adjust the cable signals in range or reprovision the modem to fix this issue.
  • May 13, 2024
And below is the snap shot of my status page
  • May 15, 2024
Thank you, The tech visited and added some splitter in between now the upstream bonded channels looks good with 43.0dBmV but Down Bonded Channels Power is -1dBmV -2dBmV.
Is it a good number ??
  • May 15, 2024
Seems like something is still not good.
Why are there so many Uncorrectables ?
Correctable and uncorrectable should be zero values. I request to contact internet service provider and ask them to make the changes accordingly.
