Arris Surfboard 33 Compatibility: TDS/Asus Mesh
  • October 13, 2024
  • 128 views
My cable service is TDS in Oregon and I am using a stock modem supplied by the provider alongside Asus CT8 Router with two nodes.  I would like to purchase a compatible modem to replace the stock router, and the ARRIS Surfboard S33 seems to be a good choice.  Would this modem be compatible with the Asus mesh and the TDS cable service?  Thanks for your time!
S33 is compatible with Asus's mesh system.
S33 will work with co-axial cable connection and fiber optics is not compatible. I would suggest checking with your internet service provider.
