Can a PoE Splitter fix the issue with S33 only allowing one connection
Hello,
I want my PC to be connected directly to the S33 with the 2.5GB port, while my router mesh system is connected to the 1 GB port.  Based on testing and what I read this is not possible as the S33 will only cater to one connection for because of IP addresses.
My question is if I buy say a Cerio POE-PD04S+ PoE Splitter plugged into the 2.5GB port will I be able to successfully connect both my PC and Mesh router to the POE?
Appreciate the tips in advance, currently I just have the Router plugged into the 2.5GB port while the PC is connected to the router’s 1GB port. I could possibly test having the router connected to the 2.5GB using its 1GB port then plugging the PC to the router’s 2.5GB but assuming that wouldn't work.
I would suggest connecting only the router to the modem through an Ethernet cable and checking the internet access. You can access only one port at a time since all the Ethernet ports are assigned the same IP address. If you are using multiple ports at the same time, that won't connect to the internet.
  • July 25, 2024
Just tested, still running into the same issue. I guess I just need a product that’s not meant for the price point the S33 is.
The Eero also does not have an extra 2.5gb port.
Really dissapointing.
