cant find my wifi logon s34 model
  • June 1, 2025
  • 49 views
I can't find my wifi account after uploading s34. On my computer
The S34 is a cable modem and does not have any built-in Wi-Fi features. It is a plug-and-play device, and to access the internet through this modem, you must connect a device directly to it using an Ethernet cable.
If you require Wi-Fi, you will also need to connect a separate router to the modem. The router will broadcast the Wi-Fi signals, allowing your devices to connect wirelessly.
