Connect S33 to HP Printer via printer pin
I’m trying to connect a HP 3056A for wireless printing. I expected to see a WPS button on the physical device, then expected to see a button on the https://192.168.100.1/ settings page. Didn’t see that anywhere, nor Surfboard Central app. There is also an option on the HP printer for a printer pin that I’m supposed to enter on the router settings. I looked on Surfboard Central for my W121 mesh network, didn’t see anything. Can someone point me in the right direction?
  • 2324 replies
  • April 26, 2023
TechRep
Cable Modem Commandos
Forum|alt.badge.img+9
  • Cable Modem Commandos
  • 45 replies
  • April 26, 2023
hi @bskinny129  the S33 is just a cable modem with no advanced settings on it therefore no WPS connection, now the W21 does not support the WPS connection either.
My best advise is to connect your printer via wifi, you can create a guest network only for your printer if you are having issues connecting to the primary network
http://arris.force.com/consumers/articles/General_FAQs/mAX-Routers-Guest-Wi-Fi-Network-Setup
  • April 26, 2023
HP’s smart app worked, thanks for the tip!
  • 2324 replies
  • April 26, 2023
Glad it worked!
