invalid IP address on my cable modem
  • April 29, 2023
  • 243 views
I keep getting an invalid IP address. I tried power cycle my modem and it is still not working.
Hello adam7719,
Can you share the invalid IP address so we can check on it ?
Hello adam7719,
  • August 29, 2023
Mine assigned 96.29.42.82 but my router, access points, or my computer alone don't recognize it.
Are you getting this IP address on the device connected to the modem directly or using router? like on the device connected to wifi network.
LoveMyLab
Guardians of the Gateways
Forum|alt.badge.img+19
  • Guardians of the Gateways
  • August 31, 2023
I replied back on your other post on this topic. “If you connect to the S33 directly from your PC and navigate to 192.168.100.1, what happens? What are you using as your primary router? The S33 is a DOCSIS 3.1 cable modem. It looks to me like the Unify USW Lite 8 is actually a POE unmanaged switch. You need a router to handle DHCP, etc.”
