Is it possible to disable the LED blinking on the WAN ethernet port?
  • February 19, 2025
  • 192 views
I have “Front Panel Lights” set to “Off under normal conditions” to disable the front LED indicator. This works wonderfully. However the WAN ethernet port’s LED is still present. With the 2.5Gb port connected to my mesh network, the LED constantly flashes green non-stop to indicate traffic.
This is very distracting at night. Is it possible at all to force a solid color or add an option to disable the LED under working conditions?
  • February 19, 2025
Not that I know of. Might try a little black electric tape or even some fingernail polish (just don’t hit the wires).
