ISP shows signal to S33 but no connection
  • March 18, 2025
  • 119 views
Breezeline shows signal to my S33 but have no connectivity through eero router or through direct hardwire to the modem!
  • March 18, 2025
How do you know its getting signal?
Were they able to activate it?
Something with the S33 is that even though it has more than 1 ethernet port, only 1 device can be connected. Try powering off the modem and the router. Wait 10 minutes.
then power on the router and give it a couple minutes to fully boot. then connect the eero to the S33 (only 1 port) and power it on. give it a couple minutes to fully boot and run a connection test/internet setup on the eero.
  • March 19, 2025
Thank you so much for responding. Turns out that the modem merely needed to be reset. All is working now!! Thanks again.
