Modem Name and Password for Arris Surfboard Model S33
  • November 12, 2023
  • 1244 views
Got the S33 to replace my Xfinity modem. Had the internet switched to this modem. Xfinity saw the connection activated on their end, but I couldn’t see the WiFi name on my end. Tried to search for Admin and used both the serial number and “password” as the password. Neither worked. I was able to get Xfinity to activate the old router in the meantime. What should I do now? Any help is appreciated.
Best answer by cwilloz
If I read your post correctly, I think you may be misunderstanding things...the S33 is only a modem to connect to Xfinity, not a Wifi gateway/router. I suspect the Xfinity modem you had was both a modem and a wifi router. I  am pretty sure you need to get yourself a separate wifi router, connect it to the S33 and the do the installation according to the manufacturer’s instructions.  You will probably have to load an app from which either AppStore (apple/android) is appropriate.  If you are only supporting a single pc, then you could connect the PC to the S33 with an ethernet cable...wifi not needed in this case, but if you are supporting PC’s and cell phones, then you will need the wifi router.
Hope thishelps
Forum|alt.badge.img+2
  • Button Mashers
  • November 12, 2023
Hope thishelps
  • November 12, 2023
Understood. I will have to return it then as I need a WiFi/gateway router.
  • November 13, 2023
Or just buy a router. Thats the route I’d go with. I prefer my modem separate from the router so I can upgrade them independently as well as then I control the firmware on the router.
When its a combo device, the ISP manages the firmware and they’re notoriously bad at it.
