Opening ports on S33 to allow for AT&T cell booster
  • December 28, 2024
  • 99 views
Hi,
I have unfortunately terrible cellular service with AT&T at my home and am evaluating options. AT&T has given me a cell booster and I am trying to connect it, and have been instructed by AT&T that I have to open the following UDP ports of the modem to allow the booster to activate: UDP / 500 IPSec port, UDP / 4500 IPSec port, Emergency Services Protocol (ESP) 50, and UDP 123 NTP port (timing synch). Initially, AT&T said my internet provider had to enable this, but I own the modem (not Xfinity, my internet provider). I seem to be unable to talk live to an ARRIS rep to resolve this. Does anyone have advice? Thank you!
The s33 is a modem only device. You change port options through the router, not the modem.
What router do you have?
  • December 30, 2024
  • January 8, 2025
Thanks for answering and sorry for the late reply!
I have an Eero 6 mesh wifi system. I’ll try to figure it out… Thanks for pointing me in the right diretion, and if you have further advice, it’s greatly appreciated!
  • January 9, 2025
Make sure the booster is connected to the eero router and not directly to the modem.
