please help with setup AX6600 with S33
  • December 18, 2023
  • 122 views
Just set up everything.  I have the s33 and max AX6600.
How do I secure my network with name and password?
Also, I have 2 routers. One is connected to the modem with ether cable. The second one is just plugged in upstairs.  Is the second one even connected or do I need that connected to an ether cable? How does the second one actually connect?
Forum|alt.badge.img+2
  • Button Mashers
  • December 18, 2023
Are you sure you have 2 routers, or a router and an extender?  If the second unit is really a router, you can use it just like an extender, and use the setup app to connect it.  I do this with an EERO mesh system and it works fine
  • December 19, 2023
Do you have the W121, w21, W122, W161system? AX6600 is a speed, not a model. If so, that usually has a router and a satellite. The router should be connected to the modem with the satellite separate for the mesh system.
Its setup and managed through the surfboard app. Have you tried that?
