Need to factory reset my surfboard S33. Depressing reset button does nothing.
reset button not workin S33
To perform a hard reset, use a pen, paperclip, or any pointed object. At the bottom of the equipment, you will see a small hole. Inside the hole, there is a reset button press and hold it for 20 seconds. You should feel a click when pressing the reset button, make sure you feel it to confirm the reset.
There is also an alternate option in the web based interface of the S33 where you can perform a soft reset
Please refer to this link, where you can find the steps to perform both a soft and hard reset.
http://arris.force.com/consumers/articles/General_FAQs/S33-Factory-Reset
