I just purchased the s33v2 modem. My old SB8200 worked just fine with both ports, but I wanted to upgrade because I wanted to get full use out of my internet speeds. I have xfinity gigabite internet. I do have a 2nd IP for my account, one hardwired to my tower, one hardwired to the wifi. The 1gb port isn’t sending signal to the wifi router. I called comcast thinking it might be something on their end, new modem and all, but they did everything on their end and believe its a hardware issue, not their end. Any advice would be appreciated.
s33 1gb port not working
In this case we would suggest you to reach out to Arris technical support by accessing arris.com/consumersupport
