S33 bad after less than 3 years?
  • April 17, 2025
  • 68 views
I bought an S33 less than 3 years ago. Recently was troubleshooting a slow internet issue and rebooted my modem by unplugging it for a minute. When I plugged back in, it never connected to the internet again (green flashing light). I has my ISP come out today and they replaced all the cables and still were unable to get my modem to connect. The tech said modems typically last only 2 years and that mine may not have the latest firmware update or is just gone bad. He installed a different modem which connected immediately. Is it true this modem could have gone bad after less than 3 years of use? It’s out of warranty now, so I’m unsure what else I can do to validate if it truly is bad or not.
Modems don't necessarily stop working after 2 years. Their lifespan depends on the hardware quality and the wear and tear of the unit.
First let us check the Ethernet port status, you can connect the modem directly to a computer and check the IP address without the coaxial cable connected.
  1. Click on the Apple menu.
