S33 cable to Orbi Router RBR750
Hi Everyone,
Do I need two cables connected from the S33 to the Orbi Router RBR750 (Ether + Internet Port 1) to get the multi-gig speeds?
Thanks for you help in advance.
Best answer by Netopia
Only connect to the yellow 2.5 ge Ethernet port for multi-gig speed.
To connect S33 to the Orbi Router one ethernet cable is sufficient to provide wireless internet to all of your Wi-Fi devices.
Its recommended to connect one end of the ethernet cable to ethernet port 1 or 2 (depending on the speed plan if lesser than 1GB 2nd port (black) can be used and If 1GB and more than that 1st port (yellow) can be used ) and the other end gets connected to the “WAN Port” of the Router.
Forum|alt.badge.img+30
  • Rockstar!
  • 273 replies
  • August 8, 2023
