S33 constant connection interruptions
  • October 19, 2025
  • 116 views
https://1drv.ms/b/c/e9ed3dab60ad9a96/EVWUd4IjOJVOqYfwressD3YBPvYlXWRWvNyoJ6S961PWpw
We are experiencing daily connectivity issues. I have attached a current event log for reference.
When you experience connectivity issues, does it seem like the modem is rebooting on its own?
If not, we’ll need to isolate the issue by connecting a computer directly to the modem using an Ethernet cable. Then, monitor the connection to see if the internet drops while connected directly.
We recommend checking the cable signal levels within the modem. If the signal levels are out of the acceptable range, they can lead to the kind of connectivity issues you're experiencing.
https://arris.my.salesforce-sites.com/consumers/articles/knowledge/S33-Cable-Signal-Levels
