My S33 modem is working fine but makes a lot of noise - a constant fluttering/chirping/skipping sound. I’ve had it for about a year but recently moved it close to my desk where it’s driving me crazy. Is this normal? Are there other routers on the market that are quiet? I use Xfinity. Thanks.
S33 constant noise loud and irritating
that for sure isn’t normal.
Is it coming from the power supply or the unit itself?
There really shouldn’t be any noise coming from it. It doesn’t have a fan or speakers.
So maybe a bad power supply or capacitor in the device maybe.
