Answer
s33 died less than 2 months of ownership
  • July 31, 2025
  • 58 views
I had an xfinity tech out today to confirm my modem died. It simply doesn't work, although it showcases it’s fine via the light on front. How does one go about getting it repaired?
Thanks in advance.
Lance
Could you please confirm the LED light status on your modem and let us know the name of your internet service provider? To help isolate the issue, we’ll need to connect the modem directly using an Ethernet cable.
  1. Click on the Apple menu.
For additional support, please visit our official support channel at www.arris.com/consumersupport.
