S33 Login to GUI web portal
I cannot log into my S33 for the first time.
Using admin for the user name and password for the password.
Even tried using the last eight digits of the serial number.
Thanks in advance.
  • 2295 replies
  • January 25, 2024
Do you get an error?
What error?
Did you try a factory reset?
Might check this post.
  • January 25, 2024
“USER NAME OR PASSWORD ERROR, PLS CHECK THEM AGAIN”
I tried the reset last weekend.
  • 2295 replies
  • January 25, 2024
you’re using all lower case?
Did you try a different browser?
When you reset, did you push and hold for up to 30 seconds while powered on?
Is there something you’re trying to log into it to do?
  • January 25, 2024
All lower case letters
Tried Chrome and Firefox
Did the reset with it powered on, but probably not for 30 seconds.
I’m gonna try that now.
  • 2295 replies
  • January 25, 2024
disconnect the coax from it, then do the reset, then try to access it without the coax connected. Some ISP’s like to lock down the access
