s33 modem loses connection for a few minutes associated with WOW config update
  • September 30, 2025
  • 213 views
Hello,
      I am experiencing a few minutes of disconnection for at least once and up to 4 times per day now.  I suspect that it is due to my internet service provider is sending a bad configuration file to my modem which causes it to lose connection for a few minutes.  This is because the event log in the modem indicates that there was a bad TLV code in the configuration file.  I am unable to convince WOW to fix this since they are overly eager to replace the S33 with their own no name brand and charge me $10 a month for renting it.  Is there a way to see the configuration file that was sent so the team at ARRIS can suggest a fix?  I’m including the log errors that repeat 4 times a day generally at the same time of day.   Are there any ways to get the WOW technical support to even look at the log files (they have refused so far).  Anyway, any ideas would be appreciated…  By the way I work with RF equipment and the signals are good, low code error rates 40 dB SNR….  The last time I called customer support they wouldn’t acknowledge that they even configure the modem and they increased the number of times they send the configuration file from 2 x per day (before I called) to 4 times per day after I called...
Date Time Event Level Description
09/29/2025 21:28:54
Notice Successful LAN WebGUI login from 50.4.168.170 on 09/29/25 at 9:28 PM
09/29/2025 21:25:07
Warning REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 21:25:05
Error Improper Configuration File CVC Format
09/29/2025 21:25:05
Critical Config File Rejected due to Invalid or Unexpected TLV 11;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 21:25:05
Notice TLV-11 - unrecognized OID;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 21:25:05
Warning MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
09/29/2025 21:24:57
Warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 21:24:46
Critical No Ranging Response received - T3 time-out;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 21:24:25
Critical Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 21:24:25
Critical Ranging Request Retries exhausted;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 21:24:25
09/29/2025 21:24:24
09/29/2025 21:24:24
09/29/2025 21:24:24
09/29/2025 21:24:24
09/29/2025 21:24:24
09/29/2025 21:24:24
09/29/2025 21:24:23
09/29/2025 21:24:23
09/29/2025 21:24:23
09/29/2025 21:24:21
Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 29; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 21:24:21
Critical No Ranging Response received - T3 time-out;CM-MAC=f(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 21:24:15
Notice CM-STATUS message sent. Event Type Code: 5; Chan ID: 8; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 21:24:14
09/29/2025 21:24:09
Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 29; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 21:24:09
Critical No Ranging Response received - T3 time-out;CM-MAC=f8:20:d2:46:c1:ed;CMTS-MAC=00:01:5c:79:c6:4a;CM-QOS=1.1;CM-VER=3.1;
09/29/2025 21:24:02
Critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 21:22:51
09/29/2025 21:22:11
09/29/2025 21:22:00
09/29/2025 21:21:01
09/29/2025 21:20:54
Critical No Ranging Response received - T3 time-out;CM-MAC=(edited private information);CMTS-MAC=(edited private information),;CM-QOS=1.1;CM-VER=3.1;
09/29/2025 21:20:54
Warning Lost MDD Timeout;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 21:20:54
09/29/2025 21:20:52
09/29/2025 21:20:18
09/29/2025 21:18:51
09/29/2025 21:15:56
09/29/2025 21:15:24
09/29/2025 17:28:26
09/29/2025 17:28:24
09/29/2025 17:28:24
09/29/2025 17:28:24
09/29/2025 17:28:24
09/29/2025 17:28:16
Warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=f(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 17:28:03
09/29/2025 17:27:48
Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 17:23:53
Notice CM-STATUS message sent. Event Type Code: 7; Chan ID: 2; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 17:23:48
09/29/2025 17:23:44
09/29/2025 17:23:44
Critical Ranging Request Retries exhausted;CM-MAC=f(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 17:23:44
09/29/2025 17:23:24
09/29/2025 17:23:19
09/29/2025 17:23:16
09/29/2025 17:23:16
09/29/2025 17:23:16
09/29/2025 17:23:06
09/29/2025 17:23:05
09/29/2025 17:22:40
09/29/2025 17:22:40
09/29/2025 17:22:40
09/29/2025 17:22:09
09/29/2025 17:22:09
09/29/2025 15:11:55
09/29/2025 15:11:53
09/29/2025 15:11:53
09/29/2025 15:11:53
Notice TLV-11 - unrecognized OID;CM-MAC=f8:20:d2:46:c1:ed;CMTS-MAC=00:01:5c:79:c6:4a;CM-QOS=1.1;CM-VER=3.1;
09/29/2025 15:11:53
09/29/2025 15:11:45
09/29/2025 15:11:33
09/29/2025 15:11:15
Notice CM-STATUS message sent. Event Type Code: 7; Chan ID: 4; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 15:11:14
09/29/2025 15:11:14
09/29/2025 15:11:14
09/29/2025 15:11:14
09/29/2025 15:11:13
09/29/2025 15:11:13
09/29/2025 15:11:13
09/29/2025 15:11:13
09/29/2025 15:11:13
09/29/2025 15:11:13
09/29/2025 15:11:12
09/29/2025 15:11:12
09/29/2025 15:11:12
09/29/2025 15:11:03
Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 29; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 15:11:02
09/29/2025 15:11:01
Notice CM-STATUS message sent. Event Type Code: 5; Chan ID: 22; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 15:10:59
09/29/2025 15:10:30
09/29/2025 15:07:23
Notice CM-STATUS message sent. Event Type Code: 5; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=(edited private information);CMTS-MAC=(edited private information);CM-QOS=1.1;CM-VER=3.1;
09/29/2025 15:07:10
09/29/2025 15:07:08
09/29/2025 15:07:08
09/29/2025 15:07:07
09/29/2025 15:06:38
09/29/2025 15:06:37
09/29/2025 13:13:29
09/29/2025 13:13:27
09/29/2025 13:13:27
The event logs you shared are related to your internet service provider. The errors shown in the logs indicate issues occurring on the provider’s end.
Only your internet service provider can investigate and resolve these errors.
We recommend checking the cable signal levels within the modem. If the signal levels are out of the acceptable range, they can lead to the kind of connectivity issues you're experiencing.
https://arris.my.salesforce-sites.com/consumers/articles/knowledge/S33-Cable-Signal-Levels
