S33 Modem/Router (not WiFi)
  • November 15, 2023
  • 313 views
Is the S33 a modem/router combo or just modem? I’m not talking about WiFi, I just need to be able to physically connect multiple devices to the LAN interface using a switch and want to make sure it hands out DHCP IP addresses. From what I’ve found the default IP is 192.168.100.1 so it does do some routing but want to make sure I can connect multiple devices on the inside.
Its a modem only device. You need to connect a router to it.
  • Button Mashers
  • November 15, 2023
The SURFBoard S33.is not a router. I do not believe that it has DHCP capabilities.
  • November 15, 2023
It’s a modem.
  • November 15, 2023
