s33 need passwoed need it
  • June 3, 2025
  • 48 views
I need the password to connect to Wifi
The S33 is a cable modem and does not have any built-in Wi-Fi features. It is a plug-and-play device, and to access the internet through this modem, you must connect a device directly to it using an Ethernet cable.
If you require Wi-Fi, you will also need to connect a separate router to the modem. The router will broadcast the Wi-Fi signals, allowing your devices to connect wirelessly.
