S33 - No internet on Wired Connection
  • November 6, 2024
  • 69 views
I have Xfinity internet using my own S33 modem and a 6g router.  My wife has concerns about emf and wants to turn off the wireless router at night.  I am up way before her and need to have internet access as I often work from home.  I want to be able to use a hardwired connection to my home office computer while the wireless router is turned off.  I thought I could use the second (bottom) modem port, but apparently cannot.  I tried simply unplugging the router from modem and plugging the ethernet cable into that modem port, but it doesn’t work either.  What is the best way to do this?
  • November 7, 2024
  1. xfinity doesn’t support using more than a single device connected to a modem only device on consumer plans. So even through the s33 has more ports, only a single device can be connected to it.
  2. Your best option? Go into the router. Many have wifi scheduling where you can schedule it on/off for time periods. Not sure what router you have but a little googling might help there.
  3. https://www.haptic-networks.com/wifi/myth-busters-wifi-safety/
