S33 Reporting Data Usage to Xfinity Tripled
  • April 29, 2023
  • 196 views
Hi All,
I purchased and installed S33 in February. It worked well. However, for March and April, Xfinity reported that 3x-4x data usage than before (and charged for additional data). My router reported 1/4-1/3 of the data usage.
So I called Xfinity to see why there is a difference in data usage being reported. Xfinity said it was because the S33 did not report data usage correctly.
Does anyone know how to solve this problem? Or is this a problem with the S33?
Thanks all for your help.
  • May 4, 2023
OK. Arris Tier 1 support couldnt help but Tier 2 support agrees to replace the unit without much discussion. Yeah!
