S33 v3 No Connectivity to Cox. Won’t activate.
  • May 20, 2025
  • 262 views
Brand new S33 shows as being active on Cox support side. I get a solid blue light but no connectivity when connected via Ethernet.  I get a webpage from Cox saying my device isn’t active. When I try to activate it, it says it’s not compatible.
Attempted to connect to a wireless router and the SSID continually shows as No Internet.
Not real sure what to do.
For your information, the S33 is compatible with COX Communications.
It could typically be a provisioning issue. We recommend checking the modem first to verify its status.
  1. Click on the Apple menu.
If the IP address starts with 169.254.., or if the media state shows 'disconnected' or the category is blank, there could be an issue with the port itself. So perform a factory reset at once
