S34 IP address configuration setting
  • March 6, 2025
  • 278 views
Is there a way to change the IP address on an S34 Cable Modem?
The S34 is a cable modem, and with a cable modem, you cannot change the IP address or modify any settings through the interface. It's a plug-and-play device. However, in gateways and routers, that's where you can configure the IP address and adjust other settings.
