S34 Needs reboot every few days
  • June 22, 2025
  • 157 views
Hi,
I recently switch out my old cable modem to a new S34 with my Xfinity service and every few days my internet stops working. Modem shows connection is still there (Blue light) but no traffic. It will stay this way until I reboot the S34 modem.
The log/status shows no obvious error, the log does show some critical issues now and then but does not seem to affect or correspond to the issues I’m having.
My old cable modem did not have this issue so I wondering if this is a faulty modem?
Status :
Startup Procedure
Procedure    Status    Comment
Acquire Downstream Channel    501000000 Hz    Locked
Connectivity State    OK    Operational
Boot State    OK    Operational
Configuration File    OK
Security    Enabled    BPI+
DOCSIS Network Access Enabled    Allowed
Downstream Bonded Channels
Channel ID    Lock Status    Modulation    Frequency    Power    SNR/MER    Corrected   Uncorrectables
20    Locked    256QAM    501000000 Hz    2.4 dBmV    40.9 dB    0    0
4    Locked    256QAM    405000000 Hz    2.4 dBmV    40.4 dB    0    0
28    Locked    256QAM    549000000 Hz    1.7 dBmV    40.9 dB    1032    4348
1    Locked    256QAM    387000000 Hz    2.5 dBmV    40.9 dB    41164    112501
2    Locked    256QAM    393000000 Hz    2.3 dBmV    43.4 dB    43280    121262
3    Locked    256QAM    399000000 Hz    2.1 dBmV    40.4 dB    40688    115873
5    Locked    256QAM    411000000 Hz    2.2 dBmV    40.9 dB    34548    82992
6    Locked    256QAM    417000000 Hz    2.4 dBmV    40.9 dB    26325    57821
7    Locked    256QAM    423000000 Hz    2.3 dBmV    40.9 dB    28122    57780
8    Locked    256QAM    429000000 Hz    2.5 dBmV    40.9 dB    25181    55313
9    Locked    256QAM    435000000 Hz    2.5 dBmV    43.4 dB    19853    39511
10    Locked    256QAM    441000000 Hz    2.6 dBmV    40.4 dB    26385    49210
11    Locked    256QAM    447000000 Hz    2.4 dBmV    40.9 dB    18146    35627
13    Locked    256QAM    459000000 Hz    2.5 dBmV    40.9 dB    19181    51050
14    Locked    256QAM    465000000 Hz    2.8 dBmV    40.9 dB    23553    57550
15    Locked    256QAM    471000000 Hz    2.5 dBmV    40.9 dB    19971    56175
16    Locked    256QAM    477000000 Hz    2.6 dBmV    40.9 dB    16914    32938
17    Locked    256QAM    483000000 Hz    2.8 dBmV    40.9 dB    14348    22083
18    Locked    256QAM    489000000 Hz    2.4 dBmV    43.4 dB    14166    28095
19    Locked    256QAM    495000000 Hz    2.7 dBmV    40.9 dB    12023    22996
21    Locked    256QAM    507000000 Hz    2.6 dBmV    40.9 dB    11313    20800
22    Locked    256QAM    513000000 Hz    2.2 dBmV    40.4 dB    11854    23621
23    Locked    256QAM    519000000 Hz    2.2 dBmV    40.4 dB    11001    18538
24    Locked    256QAM    525000000 Hz    2.1 dBmV    40.9 dB    10119    21780
25    Locked    256QAM    531000000 Hz    1.9 dBmV    40.9 dB    16051    41122
26    Locked    256QAM    537000000 Hz    1.9 dBmV    40.9 dB    6890    15658
27    Locked    256QAM    543000000 Hz    1.3 dBmV    40.9 dB    21224    83064
29    Locked    256QAM    555000000 Hz    1.0 dBmV    40.9 dB    11716    28055
30    Locked    256QAM    561000000 Hz    1.2 dBmV    40.9 dB    7652    15535
31    Locked    256QAM    567000000 Hz    0.9 dBmV    40.9 dB    8697    19663
32    Locked    256QAM    573000000 Hz    1.2 dBmV    40.4 dB    8165    15512
193    Locked    OFDM PLC    722000000 Hz    -1.5 dBmV    42.0 dB    3158955277    199586
194    Locked    OFDM PLC    957000000 Hz    -9.0 dBmV    38.0 dB    3900150312    364376
Upstream Bonded Channels
Channel ID    Lock Status    US Channel Type    Frequency    Width    Power
20    Locked    SC-QAM    35600000 Hz    6400000    43.3 dBmV
17    Locked    SC-QAM    16400000 Hz    6400000    41.3 dBmV
19    Locked    SC-QAM    29200000 Hz    6400000    43.0 dBmV
18    Locked    SC-QAM    22800000 Hz    6400000    42.5 dBmV
Current System Time:06/22/2025 11:06:45
Log :
Date Time    Event Level    Description
06/22/2025 11:03:33    Critical    Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 11:03:13    Notice    Successful LAN WebGUI login from 192.168.100.200 on 06/22/25 at 11:03 AM
06/22/2025 11:03:11    Notice    Failed LAN WebGUI login attempt from 192.168.100.200 on 06/22/25 at 11:03 AM
06/22/2025 11:02:33    Critical    Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 10:13:44    Notice    CM-STATUS message sent. Event Type Code: 6; Chan ID: 43; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 10:13:33    Critical    Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 10:12:33    Critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 10:12:07    Critical    Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:22:12    Notice    CM-STATUS message sent. Event Type Code: 6; Chan ID: 43; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:22:07    Critical    Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:22:01    Error    DBC-ACK not received;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:21:59    Warning    TCS Partial Service;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:21:59    Warning    Initializing Channel Timeout Expires - Time the CM can perform initial ranging on all upstream channels in the TCS has expired;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:21:31    Warning    RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:21:07    Critical    No Ranging Response received - T3 time-out;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:17:50    Notice    US profile assignment change. US Chan ID: 43; Previous Profile: 10; New Profile: 12.;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:13:24    Notice    CM-STATUS message sent. Event Type Code: 23; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:11:48    Warning    RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:11:35    Notice    US profile assignment change. US Chan ID: 43; Previous Profile: 11; New Profile: 10.;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:11:27    Notice    CM-STATUS message sent. Event Type Code: 5; Chan ID: 22; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:11:08    Warning    RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:11:05    Notice    CM-STATUS message sent. Event Type Code: 4; Chan ID: 19; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:10:59    Critical    SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:10:57    Critical    No Ranging Response received - T3 time-out;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:10:57    Notice    CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:10:55    Notice    CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:10:55    Critical    SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:10:35    Notice    US profile assignment change. US Chan ID: 43; Previous Profile: 12; New Profile: 11.;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
06/22/2025 07:08:24    Notice    US profile assignment change. US Chan ID: 43; Previous Profile: ; New Profile: 12.;CM-MAC=(Edited Private Information) ;CMTS-MAC=00:90:f0:24:00:00;CM-QOS=1.1;CM-VER=3.1;
The information you provided relates to cable signal levels, which should fall within an acceptable range to make sure internet quality. However, according to our records, the signal levels you mentioned are outside of that acceptable range.
 http://arris.force.com/consumers/articles/knowledge/S33-Cable-Signal-Levels
We suggest contacting your Internet Service Provider (ISP) to have them reviewed and adjusted as needed.
The other set of information you provided consists of event logs, which record errors occurring on the service. These logs indicate issues related to your internet service provider.
  • June 26, 2025
You have a bunch of errors in your line and your signal has issues according to the log. You can check the cable for kinks, damage, loose connectors, bad splitters, etc. I’d recommend moving the modem to right where the coax comes into the home and connect there. If you still get the issues, the ISP needs to check the line.
IF you didn’t have any issues before, try changing the coax cable. Could be it got kinked/damaged during the change
