set up of arris s33 - need wifi name
  • March 2, 2025
  • 172 views
I just purchased an Arris S33. It did not come with a user manual. According to Xfinity, I need the WiFi name and pswd of the device. How do I get this?
The S33 is simply a cable modem and does not have Wi-Fi capabilities, unless you have a router to connect it to. If you don't have a router, to check the internet connection on the modem, I would recommend connecting the modem directly to a computer using an Ethernet cable.
  • March 3, 2025
You bought a modem only device. Did you plan on doing that or did you think you were buying a modem/router combo device?
