Spectrum refusing to firmware update S33
  • August 27, 2025
  • 181 views
My modem is going slower than the speeds I paid for (90mbps down and 20 up instead of 1000 down and 40 up).
From an AI search it probably needs a firmware update and is not being configured to make use of all the lanes available (my oversimplified version).
Spectrum support seems to not know that they are responsible for updating the firmware. I’ve talked to 3-4 people via support and some said it’s not up to them and others said it would be done automatically.
Is there anything else I can do on my end? I’m not a normal user and need the speeds for my small business.
To help isolate the issue, please connect the S33 modem directly to a computer using an Ethernet cable. This will allow you to check whether the modem is delivering the expected speed when operating as a standalone device.
If still issue persists then we recommend checking the cable signal levels within the modem. If the signal levels are out of the acceptable range, they can lead to the kind of slow issues you're experiencing.
https://arris.my.salesforce-sites.com/consumers/articles/knowledge/S33-Cable-Signal-Levels
