Surfboard S33 cable modem
  • February 25, 2025
  • 33 views
I just bout a refurbished S33 cable modem on Amazon. Is there a light that comes on when plugged in. No light illuminated on mine.
Larry
Usually the power light comes on. Might have gotten a bad unit. If its from amazon and you just got it, usually amazon’s return/exchange is much faster than going through arris’s
  • 2292 replies
  • February 26, 2025
