surfboard S33 not reconnecting
  • January 10, 2026
  • 78 views
The power company shut off my power for several minutes to test for a possible issue. My internet worked fine beforehand, but after reconnecting power, my Arris Surfboard 33 no longer connects. I’ve tried several resets with no luck. We have Cox, but their remote help was not useful. Help?
To isolate the issue, we recommend connecting the modem directly to your computer using an Ethernet cable and then power cycling the modem. This will help verify if the internet connection is restored.
Note: Use only one Ethernet connection at a time.
If the issue persists, we suggest checking the status of the Ethernet ports.
  1. Click on the Apple menu.
