Surfboard S33v2 solid white light, buzzing with no connection
  • September 5, 2024
  • 581 views
Our Surfboard S33v2 has a solid white light with buzzing and no connections
I've done the following steps:
1. Power cycle
2. Disconnect the RG6 coax cable
3.  Have tried to connect to the GUI web portal when directly connected with a rj45 patch cable.
4. Reset button and repeated previous steps
Best answer by Anonymous
You’ll need to reach out to support mentioned on this past post.
  • September 9, 2024
