Trouble connecting to ISP Arris SurfBoard S33
  • February 23, 2026
  • 31 views
Hello,
I’ve been having issues connecting to my ISP (Optimum Online) for the last few days and they are suggesting that it is an issue with my modem. I’ve replaced my ISP installed coaxial cable with a brand new RG6 cable as there was a tear in part of the old cable. The modem is on a constant blinking green light as of Saturday 2/21 at ~12:30 AM. On checking the status, I see the following:
Startup Procedure
Procedure Status Comment
Acquire Downstream Channel 609000000 Hz Locked
Connectivity State In Progress Upstream Parameters Acquired
Boot State In Progress Upstream Parameters Acquired
Configuration File In Progress
Security  Failed BPI+
DOCSIS Network Access Enabed Denied
Downstream Bonded Channels
27 Locked QAM256 609000000 Hz 5dBmv 41 dB 0
0
Upstream Bonded Channels
Channel ID Lock Status US Channel Type Frequency Width Power
5 Not Locked SC-QAM 14000000 Hz 6400000 51.3 dbMV
From my layman understanding, most of these parameters seem okay (minus the upstream power being a little high). Is there anything else suggesting that the modem is broken, or does the problem seem to be more on the ISP’s side of things?
Thanks in advance!
The blinking LED indicates that the modem is not receiving a proper signal from your service provider. Possible causes include:
  • Scheduled maintenance
  • Unexpected local outages
  • A corroded splitter or outdoor connection point
Since you’re able to log in to the modem’s web interface, this confirms that the modem itself is functioning correctly.
We recommend contacting your internet service provider to have them verify the signal and check for any issues on their end.
