Verizon Upgrade - S34 Down
  • January 13, 2026
  • 76 views
Had an S34 running great on Xfinity network until they decided to “upgrade” the system in our area in 12/25.  After upgrade S34 was “seen” on the Xfinity network but no internet at all.  After several Xfinity service calls can get an internet signal and run a few apps via S34, but not all apps will function; can’t get internet signal to router.  Of course the Xfinity modem (that I got to diagnose) runs ok.  Any similar experiences and/or solutions?
Could you please confirm the speed plan you are currently subscribed to?
Try connecting the S34 directly to a computer using an Ethernet cable to test the connection. Please ensure that only one Ethernet device is connected at a time.
  1. Click on the Apple menu.
