will i notice a sinificant difference from a 5 year sb6190 to s33 modem on spectrum?
  • November 22, 2024
  • 68 views
Will I notice a significant /noticable speed change from a 5-year sb6190 to s33?
  • Button Mashers
  • November 22, 2024
Any performance improvement will be dependent on your ISP plan.
If your plan is up to or less than 1GB, then I would suspect not much to no performance improvement. Although the upgrade from DOCSYS 3.0 to 3.1 might give you a boost.
Hope this helps.
  • November 22, 2024
What speeds do you pay for?
What router do you have?
What speeds do you currently get wired?
And wireless?
