I have an S33 modem I recently installed only to find that Xfinity will only allow a single public IP address for non-Xfinity modems (obviously to encourage you to rent their modems….). This effectively disables the 2nd ethernet port. Has anyone come up with a simple way to get around this and utilize both ports?
Answer
Workaround for Xfinity limiting S33 modem to single active ethernet port?
How big is your home and what is your budget?
there’s a ton of routers out there and a few I’d recommend.
But there’s also the temptation to look at mesh systems if your home is big enough.
With the push for Wifi 7 a lot of the older AX stuff is on pretty solid sales and renewed.
But without knowing the size of your home and budget, its tough to recommend much.
Most of the AX generation is going to easily handle 200mbps
