wifi name and password for SB6183
  • November 19, 2023
  • 583 views
The box has no information on wifi name and password I can’t set up without putting that information in his
SB6183 is just a cable modem it doesn't have inbuilt WIFI on it so this is just a plug and play device you can access internet on direct connection so if you are looking for wifi details you need to connect separate router to the modem and you can see the WIFI credentials on the router label
  • 2275 replies
  • November 23, 2023
Do you have a router connected to it?
