wifi name and password for SB6183
  • 19 November 2023
  • 260 views
The box has no information on wifi name and password I can’t set up without putting that information in his
Best answer by SURFboard Moderator 22 November 2023, 21:40
SB6183 is just a cable modem it doesn't have inbuilt WIFI on it so this is just a plug and play device you can access internet on direct connection so if you are looking for wifi details you need to connect separate router to the modem and you can see the WIFI credentials on the router label
Userlevel 6
Badge +40
Do you have a router connected to it?
