Bought a arri sb6190 and trying to connect to a netgear nighthawk r700 but all I get is connection fail on ny device
Page 1 / 1
Try these steps:
Shut off the power on both SB6190 and Nighthawk.
Power up the SB6190, wait for all 4 lights to be solid.
Check the Ethernet cable has secure connection to SB6190 Eth port and the other end to the Nighthawk’s WAN or Internet port.
Then power up the Nighthawk.
This restart method should allow the Nighthawk to get the Internet address from the internet provider.
