Arris SBG190 no internet connection
  • January 23, 2025
  • 70 views
I came home only the 1st w lights were lite up I've unplugged both modem and router box and after that it blinks yellow and goes back like it was no internet connection at all
  • January 24, 2025
did you check with the ISP?
Can you log into it and check your cable connections?
Please try connecting the modem to a different outlet and make sure the coaxial cable is properly connected.
