Can I disable front display lights on SB6190?
  • April 4, 2024
  • 119 views
Can I disable front display lights on SB6190? I saw the same question and a reply with instructions to disable the lights but I actually don't have the option listed in the instructions. I don't know if Arris deleted that option or moved it? They are very bright and makes the room glow at night. Bought March 2024.
SB6190 have an option to turn off the LED light on the modem so if you don't see the option when you access modem GUI please try on direct connection without coax that is disconnect the coax cable from the modem and connect any device like laptop or computer to the modem LAN port to access the modem GUI. Follow the steps mentioned on the below article to turn off the lights on your modem.
http://arris.force.com/consumers/articles/General_FAQs/SB6190-Turn-Off-the-LED-Lights
