Answer
connecting extender to SB6190
  • October 28, 2023
  • 88 views
What WiFi extender goes with sb1690
SB6190 is compatible with all brand routers so you can use WIFI extenders only when connected router on this cable modem to extend WIFI signal connect WIFI extenders alone to the SB6190 cable modem will not allow you to access WIFI so please make sure you are connect router to the cable modem then the extenders.
  • November 1, 2023
what router do you have?
