loosing connection
  • January 16, 2023
  • 6 replies
  • 190 views
My SB6109 keeps loosing connection about every 2 days. I have to reboot it in order to gain wifi connection back to the router.
Forum|alt.badge.img+4
  • Button Mashers
  • 25 replies
  • January 16, 2023
Hi Tazier,
Could you please share the screenshot of “Status” page so that we can check if the cable signal levels are within the acceptable range.
You can get into the web interface by accessing 192.168.100.1 after connecting the computer directly to the modem
  • 2367 replies
  • January 16, 2023
Loosing connection. A little more details helps. The SB6190 is a modem only device. If its only the wifi devices having issues (and not wired) the modem isn’t the root cause. I’d be looking at the router that you have setup providing wifi to it.
  • January 24, 2023
I’m having the same problem...internet drops.  Here’s an event log:
(edit: MAC addresses removed by the moderator)
Mon Jan 23 19:06:04 2023 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:06:04 2023 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:06:04 2023 5 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:06:06 2023 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:06:06 2023 5 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:06:11 2023 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:06:11 2023 5 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:06:13 2023 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:06:13 2023 5 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:06:42 2023 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:06:42 2023 5 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:06:43 2023 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:06:48 2023 5 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:06:52 2023 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:06:54 2023 5 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:07:12 2023 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:07:12 2023 5 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:11:11 2023 3 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:13:38 2023 6 TLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mon Jan 23 19:21:07 2023 5 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Does this suggest something originating outside the house or more internal? I have checked the cable connection and it is tight.  I have a ASUS router downstream from the modem, but don’t believe that’s the problem.
Thanks!!
  • January 24, 2023
Here’s the cable signal levels.  Sorry for cluttering up the page. Losing signal from Xfinity several times a day for about 15 minutes. Anybody able to see something significant?
Channel
Lock Status
Modulation
Channel ID
Frequency
Power
SNR
Corrected
Uncorrectables
1
Locked
256QAM
13
477.00 MHz
2.00 dBmV
40.95 dB
1490025
3137178
2
Locked
256QAM
1
393.00 MHz
1.60 dBmV
40.95 dB
1492641
3217547
3
Locked
256QAM
2
399.00 MHz
1.50 dBmV
40.95 dB
1489183
3394864
4
Locked
256QAM
3
405.00 MHz
1.40 dBmV
40.95 dB
1474681
3552400
5
Locked
256QAM
4
411.00 MHz
1.60 dBmV
40.95 dB
1490028
3334054
6
Locked
256QAM
5
417.00 MHz
1.60 dBmV
40.95 dB
1471291
3490058
7
Locked
256QAM
6
423.00 MHz
1.50 dBmV
40.37 dB
1463192
3579749
8
Locked
256QAM
7
429.00 MHz
1.60 dBmV
40.95 dB
1476748
3314640
9
Locked
256QAM
8
435.00 MHz
1.50 dBmV
40.95 dB
1484340
3482469
10
Locked
256QAM
9
453.00 MHz
1.80 dBmV
43.38 dB
1444671
3350273
11
Locked
256QAM
10
459.00 MHz
1.70 dBmV
40.95 dB
1470148
3362263
12
Locked
256QAM
11
465.00 MHz
1.80 dBmV
40.37 dB
1466373
3480603
13
Locked
256QAM
12
471.00 MHz
1.80 dBmV
40.95 dB
1476608
3427931
14
Locked
256QAM
14
483.00 MHz
2.00 dBmV
43.38 dB
1468059
3612533
15
Locked
256QAM
15
489.00 MHz
2.00 dBmV
40.37 dB
1497131
3612644
16
Locked
256QAM
16
495.00 MHz
1.80 dBmV
40.95 dB
1451210
3659647
17
Locked
256QAM
17
501.00 MHz
1.90 dBmV
40.37 dB
1498696
4139870
18
Locked
256QAM
18
507.00 MHz
2.10 dBmV
40.95 dB
1486242
3670563
19
Locked
256QAM
19
513.00 MHz
2.00 dBmV
40.95 dB
1507455
3938275
20
Locked
256QAM
20
519.00 MHz
1.90 dBmV
40.95 dB
1485734
3669369
21
Locked
256QAM
21
525.00 MHz
1.70 dBmV
40.37 dB
1468720
3630589
22
Locked
256QAM
22
531.00 MHz
1.60 dBmV
40.95 dB
1467917
3856220
23
Locked
256QAM
23
537.00 MHz
1.70 dBmV
40.95 dB
1532553
3888868
24
Locked
256QAM
24
543.00 MHz
1.60 dBmV
40.95 dB
1675456
4784165
25
Locked
256QAM
26
555.00 MHz
1.50 dBmV
40.40 dB
11778
20646
26
Locked
256QAM
27
561.00 MHz
1.40 dBmV
41.90 dB
12062
22645
27
Locked
256QAM
28
567.00 MHz
1.70 dBmV
41.10 dB
11294
23926
28
Locked
256QAM
29
573.00 MHz
1.50 dBmV
41.10 dB
12164
22334
29
Locked
256QAM
30
579.00 MHz
1.50 dBmV
41.90 dB
12255
24863
  • 2367 replies
  • January 24, 2023
@Vizzy Please start your own thread so your info isn’t confused with the OP’s info. I had to read back to see that this wasn’t your post and it gets things confused.
  • 2367 replies
  • January 24, 2023
@Vizzy But you are having line issues from your modem connection info
